Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
linked panelboards in Revit
1 REPLY 1
353 Views, 1 Reply
Can you circuit to a panelboard if it is in a linked model?
1 REPLY 1
CoreyDaun
Hi Michelle, welcome to the Discussion Groups!
Unfortunately, no. You cannot circuit or otherwise connect systems with elements in a linked model. This also means that you cannot circuit elements (i.e. motors in a separate mechanical model) that reside in a linked model to a panel in the current model.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
