Revit MEP
Member
ahkelly
Message 1 of 3 (358 Views)
how to create a switchboard?
358 Views, 2 Replies
10-07-2013 06:12 AM
I have many switchboards in the building with different lenghs depends on the number of sections needed. For instance, the attached PDF layout is a 14'-8" x 2' switchboard that consists of a distribution panel, 8 panelboards and 3 transformers.  Is there a way to create a switchboard like this in Revit?
New Member
jspivack
Message 2 of 3 (214 Views)
Re: fuse switchboard
03-05-2014 09:25 AM in reply to: ahkelly
I need the fuse swithchboard, do you have one
CADastrophe
Message 3 of 3 (196 Views)
Re: how to create a switchboard?
03-06-2014 06:36 AM in reply to: ahkelly
Hmm... this post must've have been missed! My apologies to the original poster!
Each "panel" portion of the switchboard would have to be an independent Family. If you are using a newer version of Revit, one method of creating this would be to model all of the modular piece as Electrical Equipment: Panelboards, marked them as "Shared", and then load them into a "host" Electrical Equipment Family: "Switchboard" and assembled as appropriate. Once loaded into the Project, each Shared component will act independently as it's own Panel and can be supplied by the same Host Family that it is embedded within. Each of the sub-components will be be Scheduled and Tagged as an independent element in the Project.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
