I made this fancoil and plenum box pasted below..but the plenum box looks like a spider being lost in it and making some random spider webs
I tried disabling all below graphic options and closed and reopend the file but the issue still exist
any help is greatly appreciated ..
Solved by Mehdi.Kardehi. Go to Solution.
Does it display like that on other computers? (Assuming that there is another computer with a different graphics setup)
Haven't try it on another PC yet but the strange thing is that the problem stays even if I print it...so the problem might have caused from somewhere else?
below is a snapshot of pdf print of the same thing...The print out is even worse....as you see there is an additional spider dangling off the fancoil here!
any thoughts?
Found the issue
The category was duct fitting...I changed it to duct accesories and the extra lines disappeared.... 🙂
