Revit MEP Forum
graphic display issue
3 REPLIES 3
377 Views, 3 Replies
I made this fancoil and plenum box pasted below..but the plenum box looks like a spider being lost in it and making some random spider webs
I tried disabling all below graphic options and closed and reopend the file but the issue still exist
any help is greatly appreciated ..
3 REPLIES 3
CoreyDaun
Does it display like that on other computers? (Assuming that there is another computer with a different graphics setup)
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Haven't try it on another PC yet but the strange thing is that the problem stays even if I print it...so the problem might have caused from somewhere else?
below is a snapshot of pdf print of the same thing...The print out is even worse....as you see there is an additional spider  dangling off the fancoil here!
any thoughts?
Found the issue
The category was duct fitting...I changed it to duct accesories and the extra lines disappeared.... 🙂
