Revit MEP
Message 1 of 2 (553 Views)
filtering piping in Revit MEP 2012
553 Views, 1 Replies
10-10-2011 07:01 AM
What is the best way to filter piping?  As all pipes turn on or off based on the filter, if I only want waste and vent, and not supply, how best to make a filter for that?  I have tried by system type, but some fittings do not change to the system they are connected to, so on the waste and vent plan the supply piping is turned off, by the filter but the fittings remain.
To fix this, I made multiple pipe types, and also modified every fitting to have similar pipe type names, and modified the Gas pipe type to use the gas fitting.  This is cumbersome and also doesnt always work.  The other downside is if Revit gets new fittings, I need to re-modify them all again.
Shouldnt this filtering be partly built into Revit, especially for the MEP version, as every MEP job i am sure will have to have filtering of different pipes as well as ducts?
Product Support
Message 2 of 2 (527 Views)
Re: filtering piping in Revit MEP 2012
10-11-2011 06:18 AM in reply to: jjcrocco
Your filter needs to apply to more than just pipes. In your filter you should check the boxes for Pipe Accessories, Pipe Fittings, Pipe Insulation, and Pipes and create the filter based on the System Classification.
If you open the Systems-Default template you will see these filters already created.
David Pothier
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
