Revit MEP Forum
filter & control the Archi Revit Reference catagoies
2 REPLIES 2
418 Views, 2 Replies
Hi. Everyboday .. Good day to u Smiley Happy
Please help me to give advice how to filter & control the Archi Revit Reference catagoies ..(for example .. I want to be off the Demolish Categories .)
Many Thanks ,
Smile
2 REPLIES 2
CoreyDaun
In order to control the appearance and visibility of the Categories belonging to a linked model separate from your model's settings, go to Visibility/Graphics Overrides » Revit Links. Under Display Settings for the link(s), click on the button which will read either "By Host View" or "Custom". This will take you to another dialog titled "RVT Link Display Settings" which appears just like V/G. In the first tab, set the top option to "Custom" and then you can go to the other tabs (set the pull-down at the top to read "Custom") and set the visibility as desired.
in reply to: CoreyDaun
Thank You Very Much for your Reply :Smiley Happy
