Adding sizes to the XML file should work fine. You'll need to close and
Re-start Revit Systems for the new sizes to appear in the list.
For duct, you can also simply type a new size in the size combo box if you
are doing a "one off" size and don't always want it to be available.
jason
"jkemble" wrote in message
news:5325910@discussion.autodesk.com...
What I am looking for is increaseing the size of the actual duct. Right now
the maximum size is 96 or 98 inches
and was wondering if I can just add sizes to the xml file
wrote in message news:5325231@discussion.autodesk.com...
I just got a reply from John Henry in regards to a question I had about Pipe
Sizes. His reply may help you with your question. I've modified his reply
to work with ductwork instead of piping.
Go into Settings/Project Units/HVAC, the default Duct units are set to whole
inches, just change to nearest 1/2" or whatever you
may need.
Hope John's reply is as helpful to you as it was for me
