Ok, so i have some very complicated tags. I was wondering if there was a way to make certain text in the tag one color, and other text in the same tag a different color to help the reader snap his eye to the information in the tag that he is looking for. Is this possible? if so how! Thanks!
Solved by CoreyDaun. Go to Solution.
The Label elements themselves can be assigned different colors. This can be done by creating a duplicate Label Type and assigning a color to it. (Select the Label, go to Type Properties, click "Duplicate...", and define the color.)
You cannot, however, assign differing colors to specific text WITHIN the same Label element.
