Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
copied pipe fittings don't "insert"
3 REPLIES 3
rhots
832 Views, 3 Replies
Hi, am I missing something here? If I try to copy, say a branch pipe and associated tee a few feet down the line, it does not break into the pipe as it would if I inserted a tee.
REVIT MEP 2013
Rick
3 REPLIES 3
abulla
in reply to: rhots
That is correct, 2014 doesn't break the pipe either. You'll have to copy the pipe and reconnect each time.
rhots
in reply to: rhots
does that mean there is an actual "reconnect" command?
abulla
in reply to: rhots
No, but you can either drag the end of the pipe back to the main, or use Extend, or Extend Multiple to do a bunch at once.
