Is there a way to constrain duct or pipes or any other system elements to the bottoms of beams from a linked structural file? I am just trying to save some time when I find a conflict. Rather than taking each piece of duct and re drawing it or losing taps.
- Bil
Solved by Alaaeldin_Alsahli. Go to Solution.
Yes and no
If your building is only one story building then you will be able to so, by using the Align tool to aligne the bottom of the beam with the top of the duct and locking them.
But if you have multiple levels the align tool won't Work.
The Best Workflow I found so far,
First, make sure that the beams are been created with a level associated with 0 Offset.
Then create copy monitors STR level with an offset that will align with the bottom of beam.
Finally you need to associate these MEP elements to this copy monitored level
Here is a video for these steps
https://chronicle.autodesk.com/Main/Details/93144e51-680c-4071-a62b-4c554b694633
The main Issue with this workflow is that, if the beam is been moved by editing its Offset instead of moving the level, you may not be noticed. So you need to contact your structure people and ask them if they could move the beam by moving the level in question. This is What BIM execution plan is all about, create a workflow where all disciplines need to follow, I know is hard but it is doable as long if everyone stick to it.
Any other suggestion will be helpful
