I am trying to place receptacles on walls (face hosted). I did the first floor with no problem but the second floor only works for the ouside walls. The interior walls will not host the element, it keeps trying to attach to the ceiling. The interior wallls are also very hard to see like they are greyed out. Obviously something is set up wrong but I can't figure it out. can somebody help?
Lyn
Solved by SteveKStafford. Go to Solution.
Sounds like the view is using an underlay and interfering with selection. If you are using 2014 or 2015 there is also an option to tell Revit not to Select Links (pull down under the Modify button).
Well if there are no spaces then perhaps there are no walls either? The walls you are seeing are probably the underlay of the lower floor. Look in the properties of the view, parameter: Underlay. It probably says Level 1 or something like that. That means Revit is showing the floor below. Change that to none and you'll see what's really there.
Have a look at your 3D view. Is there more than one floor?
Have you adjusted the levels of your project to match those of the architecture file?
Thank you for trying to help Steve.
I still don't know what is wrong with the plan I was using but I made a new view from the architectural floor plan view and this one works fine. However it's in the wrong section which is annoying and I also have to edit the template if I want to alter the view range so I know this isn't how it's supposed to be but at least it works.
I've only done one project before and that was 5 years ago so a lot has changed and even more has been forgotten. Unfortunately I am under enormous pressure here with lots of other work needing my attention so I haven't had the time to read up properly and probably made some errors with the initial set up. I did have an error with the levels which has since been fixed but it seems like the change doesn't affect everything - view options - at any rate. I guess it only works if its set up right in the beginning.
A project needs to start out with some basics:
There are other subtle things like worksets that can factor in as well, but assuming the above is all done, you're ready to start adding your own work.
