Revit MEP
Valued Contributor
bvm76
Message 1 of 6 (455 Views)
Accepted Solution
cable tray connector
455 Views, 5 Replies
11-18-2013 04:38 AM
i am trying to make a cable tray fitting but i can't figure out why the cable tray connector is not in line with the face of the tray that i selected. the width is fine and the height is the problem. Please see attached.
*Expert Elite*
CADastrophe
Message 2 of 6 (427 Views)
Re: cable tray connector
11-18-2013 06:39 AM in reply to: bvm76
Can you attach the Family file? Also, what version of Revit are you using?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
bvm76
Message 3 of 6 (419 Views)
11-18-2013 07:47 AM in reply to: CADastrophe
please see attached.
i am using revit 2013.
Valued Contributor
EnlInt
Message 4 of 6 (412 Views)
11-18-2013 08:16 AM in reply to: bvm76
It has to do with that the connector is connected to the U-shaped face. It connects to the center of gravity of the face. Solution is to connect it to a workplane or alternatively create a (small) object were you can connect your connector to. This object with connector can than be located/placed in the right spot. In your case I would go for workplane based connector.
*Expert Elite*
CADastrophe
Message 5 of 6 (402 Views)
11-18-2013 08:58 AM in reply to: bvm76
Too add to EnlInt's suggestion of creating a dedicated extrusion to host the Connector: you can disable that extrusion's Visibility  and the Connector will still be available. Alternatively, you can create the core extrusion as a solid bar and use a Void Extrusion to carve our the cavity, which will leave the connector centered on the face.
Valued Contributor
bvm76
Message 6 of 6 (365 Views)
11-20-2013 09:06 AM in reply to: CADastrophe
I created a solid sweep with the same width and height as the U-face tray and it works. Thanks guys!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
