Revit MEP
Valued Contributor
bvm76
Message 1 of 6 (560 Views)
cable tray connector
560 Views, 5 Replies
11-18-2013 04:38 AM
i am trying to make a cable tray fitting but i can't figure out why the cable tray connector is not in line with the face of the tray that i selected. the width is fine and the height is the problem. Please see attached.
CADastrophe
Message 2 of 6 (532 Views)
Re: cable tray connector
11-18-2013 06:39 AM in reply to: bvm76
Can you attach the Family file? Also, what version of Revit are you using?
Valued Contributor
bvm76
Message 3 of 6 (524 Views)
11-18-2013 07:47 AM in reply to: CADastrophe
please see attached.
i am using revit 2013.
Valued Contributor
EnlInt
Message 4 of 6 (517 Views)
11-18-2013 08:16 AM in reply to: bvm76
It has to do with that the connector is connected to the U-shaped face. It connects to the center of gravity of the face. Solution is to connect it to a workplane or alternatively create a (small) object were you can connect your connector to. This object with connector can than be located/placed in the right spot. In your case I would go for workplane based connector.
CADastrophe
Message 5 of 6 (507 Views)
11-18-2013 08:58 AM in reply to: bvm76
Too add to EnlInt's suggestion of creating a dedicated extrusion to host the Connector: you can disable that extrusion's Visibility  and the Connector will still be available. Alternatively, you can create the core extrusion as a solid bar and use a Void Extrusion to carve our the cavity, which will leave the connector centered on the face.
Valued Contributor
bvm76
Message 6 of 6 (470 Views)
11-20-2013 09:06 AM in reply to: CADastrophe
I created a solid sweep with the same width and height as the U-face tray and it works. Thanks guys!
