Revit MEP Forum
cable tray connector
9 REPLIES 9
Message 1 of 10
bvm76
2206 Views, 9 Replies
i am trying to make a cable tray fitting but i can't figure out why the cable tray connector is not in line with the face of the tray that i selected. the width is fine and the height is the problem. Please see attached.
Please mark Accept as Solution if your question is answered!
Thank You.
9 REPLIES 9
Message 2 of 10
CoreyDaun
in reply to: bvm76
Can you attach the Family file? Also, what version of Revit are you using?
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 10
bvm76
in reply to: CoreyDaun
please see attached.
i am using revit 2013.
Thank You.
Message 4 of 10
L.Maas
in reply to: bvm76
It has to do with that the connector is connected to the U-shaped face. It connects to the center of gravity of the face. Solution is to connect it to a workplane or alternatively create a (small) object were you can connect your connector to. This object with connector can than be located/placed in the right spot. In your case I would go for workplane based connector.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 5 of 10
CoreyDaun
in reply to: bvm76
Too add to EnlInt's suggestion of creating a dedicated extrusion to host the Connector: you can disable that extrusion's Visibility  and the Connector will still be available. Alternatively, you can create the core extrusion as a solid bar and use a Void Extrusion to carve our the cavity, which will leave the connector centered on the face.
Message 6 of 10
bvm76
I created a solid sweep with the same width and height as the U-face tray and it works. Thanks guys!
Thank You.
Message 7 of 10
in reply to: L.Maas
Is this solution able to fix this? I've gone in into the bend family but can't find how to make this connection auto-connect. Connector Issues - Cable Tray.PNGFIX CABLE TRAY CONNECTIONS.PNG
Message 8 of 10
fabiosato
It seems that the bending family has some issues, the 600 number you mention is the cable tray width, right?
If you can share the family of the bend would be easier to understand the problem.
As first check, you are using metric bend family?
Fábio Sato
Message 9 of 10
in reply to: fabiosato
Hi
Thank you for the response. I actually brought in new families from the internet instead and replaced the one that wasn't connecting correctly so unfortunately I no longer have the family! Still unsure as to how I would have fixed it so would have been useful to find out.
Message 10 of 10
fabiosato
I have a MEP fitting course at Pluralsight, it may give you a base knowledge to create this kind of family.
Fábio Sato
