Revit MEP Forum
Yes/No Parameter & Calculated Values
1 REPLY 1
smbrennan
788 Views, 1 Reply
I have a Shared Parameter that is a simple Yes/No that I am using for a Visibility Control. However, that same parameter can also be beneficial in a schedule, but rather than seeing Yes or No, I want to see different words. This must be possible, but how?
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
1 REPLY 1
smbrennan
in reply to: smbrennan
Literally just figured it out, I was using the wrong syntax. It should be:
if(<PARAMETER NAME>,"<Word for Yes>", "<Word for No>")
Obviously no Brackets. "Word for Yes" is used where the Yes/No option is Yes. Use the word you wish to use instead of Yes. Same concept for "No."
Shawn B.
