Revit MEP
Member
bbrovont
Message 1 of 4 (334 Views)
Accepted Solution
Wire Size Label bug
334 Views, 3 Replies
11-05-2012 10:58 AM
I seem to have discovered a bug with the wire size label.  If I edit the wire type so that a neutral is not required, the label stops showing the ground conductor size as well.  I can see it in the properties window, it shows the 3 hot sizes and the ground size, it just will not show up in the view.  Anyone have a suggestion to fix this, or seen this before?
Member
bbrovont
Message 2 of 4 (331 Views)
Re: Wire Size Label bug
11-05-2012 11:12 AM in reply to: bbrovont
I just discovered that the wire size parameter in the power system properties shows the correct number of conductors, but the wire size parameter for the actual wire geometry only shows the hot conductors, if there is no neutral.  Hopefully someone else has seen this before, and has a solution.
Product Support
Chris.Aquino
Message 3 of 4 (234 Views)
11-21-2012 11:58 AM in reply to: bbrovont
I would make sure that "Share Neutral Conductor" and "Share Ground Conductor" are both unchecked for the wire type. The tag and Properties Palette should now show the correct number of conductors.
Chris Aquino
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
The Revit Clinic
@Revitclinic
Member
bbrovont
Message 4 of 4 (86 Views)
02-18-2014 08:38 AM in reply to: Chris.Aquino
Sorry, Chris.  I hadn't realized that you responded to my post.  Thank you very much, that solved the problem.  I hadn't realized that setting was available.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
