Revit MEP
Message 1 of 2 (132 Views)
Accepted Solution
WHILE loop?
132 Views, 1 Replies
08-23-2013 12:52 PM
Can you do while loops in revit? If not, how do you track three variables? For example If 10<20, and 20<30, then C=1. the only problem is that C can have 4 values and logically can have more t...
*Expert Elite*
CADastrophe
Message 2 of 2 (124 Views)
Re: WHILE loop?
08-23-2013 01:26 PM in reply to: michaelmead
michaelmead wrote:
"Can you do while loops in revit? If not, how do you track three variables? For example If 10<20, and 20<30, then C=1. the only problem is that C can have 4 values and logically can have more than one correct value based on the values of A and B...? any programers out there? Thanks!"
A while loop is not possible within Revit's... less than stellar formulaic abilities. You can use a series of nested IF/THEN/ELSE statements. For example, this formula defines the Integer Value of "ParamC" based on the values of "ParamA" and "ParamB":
if(and(ParamA>20, ParamB>20), 35, if(and(ParamA<20, ParamB>20), 25, if(and(ParamA<20, ParamB<20), 15, 5)))
This formula checks the conditions and returns the results as listed below:
          IF AND...             THEN…
"ParamA" "ParamB"    "ParamC"=
   >20           >20                35
   <20           >20                25
   <20           <20                15
None of the above              5
Hope that helps!
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
