Revit MEP
Active Contributor
CADArmor
Message 1 of 3 (415 Views)
Volume of Mechanical Ducts
415 Views, 2 Replies
10-03-2012 10:33 PM
Is there a way other than manual calculations to calculate the volume of mechanical ducts in REVIT MEP 2012?
Picture attached shows a duct system highlighted in yellow. I need to calculate the entire volume of that duct system. Can someone please help?
CADastrophe
Message 2 of 3 (377 Views)
Re: Volume of Mechanical Ducts
10-08-2012 07:53 AM in reply to: CADArmor
I would image that you could create a Duct Schedule sorted by their individual size Parameters (i.e. Height, Length, Diameter) and create a Calculated Value to total up the volume. In fact, I believe that there is already an "Area" parameter that may of some use. For each type of Duct (Rectangular, Round, Oval) you would need a separate Calculated Value or perhaps a Separate Schedule to keep it cleaner. I don't think that this would account for Duct Fittings, though.
Distinguished Mentor
asommer
Message 3 of 3 (358 Views)
10-09-2012 11:36 AM in reply to: CADArmor
The area that Revit gives in the schedule is Sheetmetal area.  It's kinda odd that volume isn't here for ducts.  You would have to do Height * Width * Length for Rect duct, and the other thing for Round.  You can sort the schedule by system name, set up the calculated values to calc the Volume of each duct, and set the "Volume" to calculate totals in the formatting tab.  It is a lot to do, but I had done this to calculate total duct weight on a project.
Good Luck!
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
