Revit MEP
CVMN0501
Message 1 of 4 (368 Views)
Accepted Solution
Visibility of surface patterns
368 Views, 3 Replies
08-25-2013 11:45 PM
Hi All,
How do i turn off surface patterns of floors quickly? The situation is, the MEP group that i work with receives Architectural revit model from some other consultant, previously they send us models where in floors doesn't have colors in its surface pattern, which is just the way how drawings are presented in MEP, but recently they have incorporated colors in the surface pattern of floors to differentiate the finished floor. How do i turn this off? The only way i see is i need to remove the colors from the surface pattern in the materials editor. Any other way to do this quicker? since the modeling stage is still on-going, our group is going to keep receiving new models, and i'd do the process all over again.
*Expert Elite*
CADastrophe
Message 2 of 4 (348 Views)
Re: Visibility of surface patterns
08-26-2013 07:41 AM in reply to: CVMN0501
The simplest way would be to modify the View Templates (if you're using them) or the View's Visibility/Graphics Overrides. Under the Model Categories tab, locate "Floors". Under the "Projection/Surface"/"Patterns" column, click "Override...". In the following dialog, clear the checkbox for "Visible" and the Floor Patterns should no longer be displayed.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
CVMN0501
Message 3 of 4 (333 Views)
08-26-2013 07:57 PM in reply to: CADastrophe
That worked. Thanks! I'll just have to transfer the view template from file to file when we receive new models.
Valued Contributor
Message 4 of 4 (222 Views)
12-20-2013 11:46 AM in reply to: CADastrophe
OMG! Thanks so much for your reply. I searched forever for that viz control.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
