Revit MEP Forum
View Range
1 REPLY 1
216 Views, 1 Reply
View Range
I have an issue with a parking garage. How do I set up the view range for a garage. From the north end of the floor to the south end changes 10'. The problem is that when I get everything on the south end of parking level 1 visible then everything on the north end of level 1 is not visible. If I change the view range to include everything on the north end of level 1 then it make everything that is on the level below on the south end visible. Any suggestions. I have attached a pic as an illustration.
1 REPLY 1
It sounds link you'll need to use a Plan Region on approximately 1/2 of the floor plan for each level of the parking garage. This will allow the Plan Region to have a different cut-plane than the portion not in the Plan Region
