I am working in a view & just want to see the steel. The top of steel is at 13'1" & I set my view range top at 13'1" & cut it at 13'0". This has worked in multiple views in the past in this project with no problems. For some reason my steel is not being shown although I can see the columns & everything is on. I also adjusted the view range multiple times(spent at least an hour on this & I know way to much time). Any ideas or suggestions why this is not working?
Solved by thombrady. Go to Solution.
Double Check that the steal is in the correct elevation. then create a view template from a view that worked before make sure to uncheck view range action. thats my best advice
I am assuming you have verified the structure is actually there. Cut a section, looked at a 3d view of the floor, etc. Changing your view ranges as described should work so I am assuming it is something else.
- Try changing your detail levels. I beleive in the past I have not been able to see beams in Coarse and had to put it on medium
- Check vg to make sure structural elements are all on.
- Check vg "revit links" tab and make sure the revit model in not unchecked.
- Check vg "worksets" and make sure the workset the struct model in on is not set to hidded
I figured it out! It was a plan region, someone had drawn it in & it locked everything I tried to do. Thanks for the replies.
