Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Value on Schedule rounded from decimal number
2 REPLIES 2
5236 Views, 2 Replies
I am trying to create equipment schedule but some of the values changes from decimal number to integer (please see attached screenshot). Please advise how to retain the decimal number. Thanks in advance.
2 REPLIES 2
CoreyDaun
That's a matter of the precision as defined by the Project Units (located on the Manage tab). "Wattage" by default is set to a precision of zero decimal places. In this dialog, set the 'Discipline:' pull-down to Electrical and then click on the button in the 'Format' column for Wattage. Here, you can control the precision via the "Rounding:" pull-down menu.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Thats great!!!
Thanks Corey
