Revit MEP
Member
Message 1 of 2 (190 Views)
VAV box offset
190 Views, 1 Replies
10-04-2012 07:49 AM
Hi
In Revit 2009, VAV box offset means distance between centerline of it in height and floor.
If you input same offset for duct, everything is ok and no additional fitting is needed.
But in Revit 2013, VAV box offset means distance between bottom of it and floor that makes an
additional fitting between VAV box and duct.
How can I change offset position to make it work like Revit 2009.
Aneesh
*Expert Elite*
CADastrophe
Message 2 of 2 (164 Views)
Re: VAV box offset
10-08-2012 07:42 AM in reply to: mars3
That would be based on the Family itself, not a setting in the program or project. If you open the Family for editing and go to the Front View (Elevation), the model should be centered vertically on a Reference Plane which is marked with "Defines Origin" and "Is Reference: Center (Elevation)" under the Reference Plane's Properties. See image of the "Out Of The Box" RMEP 2013 VAV Box Family.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
