Revit MEP
Member
mars3
Message 1 of 2 (201 Views)
VAV box offset
201 Views, 1 Replies
10-04-2012 07:49 AM
Hi
In Revit 2009, VAV box offset means distance between centerline of it in height and floor.
If you input same offset for duct, everything is ok and no additional fitting is needed.
But in Revit 2013, VAV box offset means distance between bottom of it and floor that makes an
additional fitting between VAV box and duct.
How can I change offset position to make it work like Revit 2009.
Aneesh
CADastrophe
Message 2 of 2 (175 Views)
Re: VAV box offset
10-08-2012 07:42 AM in reply to: mars3
That would be based on the Family itself, not a setting in the program or project. If you open the Family for editing and go to the Front View (Elevation), the model should be centered vertically on a Reference Plane which is marked with "Defines Origin" and "Is Reference: Center (Elevation)" under the Reference Plane's Properties. See image of the "Out Of The Box" RMEP 2013 VAV Box Family.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
