Revit MEP
Valued Contributor
SLDBrown
Message 1 of 2 (208 Views)
Using a Scale function as a Parameter in families
208 Views, 1 Replies
08-29-2013 06:30 AM
I need to build a family for flanged expansion joints (see attached). I can easily develop and modify the size of the flanges and fitting length using simple paramters. I need some input on how to add a parameter to affect the size of the donut shaped middle. Can a scale function be used as a parameter?
Steve
CADastrophe
Message 2 of 2 (191 Views)
Re: Using a Scale function as a Parameter in families
08-29-2013 08:10 AM in reply to: SLDBrown
Something like that can be accomplished one of two ways. If that dimension is always a proportional size to the Pipe's nominal size, a simple parametric formula shouldn't be terribly difficult to concoct. If it isn't directly proportional, perhaps including this information into the Family's LookUp table would be best (assuming that the Family uses one).
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
