Revit MEP Forum
Using SHIFT key to draw flex duct
1 REPLY 1
Mehdi.Kardehi
1208 Views, 1 Reply
Hi All
SHIFT key does something similar to AutoCAD ortho function when I am drawing rigid ducts.
Why it doesn't work for flex ducts? Is that a way to do same for flex ducts?
Cheers,
M
1 REPLY 1
CoreyDaun
in reply to: Mehdi.Kardehi
I assume that's by design - Flex Duct is not intended to be drawn with the same precision as Rigid Duct. If you are hard-pressed to attain a perfectly straight segment of Flex Duct, first draw a Detail Line and then draw the Flex Duct over it, snapping to the endpoints of the Detail Line.
