I am quite confused about Using Filters in Visibility and Graphic Display, who would let me know the details about this, had better give an example on electrical area.
Thanks!
Solved by TonyVav. Go to Solution.
What are you trying to accomplish with filters? I use them to control visability and color of pipe and duct systems, shading worksets (i.e. Shading mechanical systems on a piping sheet). There are many ways to use filters.
Thank you TonyVav, actually I just begin to learn revit MEP, have not used in any where yet, just feel filter makes me confused, I guess I need read wikihelp more..
You are welcome. Check out this video on you tube. It uses ductwork in the demo but the same goes for piping. http://www.youtube.com/watch?v=DDyysnLJJfI
Good luck, Tony
