Revit MEP
Active Contributor
max.a.hollander
Message 1 of 3 (167 Views)
User malfunction SHX to TFF
167 Views, 2 Replies
08-27-2012 04:19 PM
So im trying to convert a SHX file to a TTF file for my companys title block in revit
while i was trying to do this i accidently changed the default program to open SHX file type to Autocad.  I know this is incorrect.  Any suggestions for fixing this?
i wasnt able to convert SHX to TTF
*Expert Elite*
CADastrophe
Message 2 of 3 (143 Views)
Re: User malfunction SHX to TFF
08-28-2012 05:47 AM in reply to: max.a.hollander
I think that you should be able to right-click on an .shx file and select "Open With" » "Choose default program..." from the menu. There should be a checkbox in the following dialog box "Always use the selected program to open this kind of file". Check it and set it to open in Notepad. Then it won't launch in AutoCAD anymore. I'm on Windows 7.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Mentor
julianjameson8403
Message 3 of 3 (134 Views)
08-28-2012 07:49 AM in reply to: max.a.hollander
Try this tool to remove your user created association:-
Unassociate Tool
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
