Revit MEP Forum
User malfunction SHX to TFF
2 REPLIES 2
358 Views, 2 Replies
So im trying to convert a SHX file to a TTF file for my companys title block in revit
while i was trying to do this i accidently changed the default program to open SHX file type to Autocad.  I know this is incorrect.  Any suggestions for fixing this?
i wasnt able to convert SHX to TTF
2 REPLIES 2
CoreyDaun
I think that you should be able to right-click on an .shx file and select "Open With" » "Choose default program..." from the menu. There should be a checkbox in the following dialog box "Always use the selected program to open this kind of file". Check it and set it to open in Notepad. Then it won't launch in AutoCAD anymore. I'm on Windows 7.
julianjameson8403
Try this tool to remove your user created association:-
Unassociate Tool
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
