Why i can't used the cables tray default fitting setting to turn around?
Only can go straight forward .Cannot turn 45 or 90 degree at same level
I already load all fitting in the same file.
Solved by abulla. Go to Solution.
Make sure your cable tray fittings are loaded into the project, then go to the type properties of the cable tray and make sure the fittings are assigned to that type.
