Revit MEP
macz_chung
Message 1 of 3 (153 Views)
Urgent need helps Thx a lot (about Revit MEP2014 cables tray)
153 Views, 2 Replies
01-14-2014 07:48 AM
Why i can't used the cables tray default fitting setting to turn around?
Only can go straight forward .Cannot turn 45  or 90 degree at same level
I already load all fitting in the same file.
abulla
Message 2 of 3 (148 Views)
Re: Urgent need helps Thx a lot (about Revit MEP2014 cables tray)
01-14-2014 07:57 AM in reply to: macz_chung
Make sure your cable tray fittings are loaded into the project, then go to the type properties of the cable tray and make sure the fittings are assigned to that type.
macz_chung
Message 3 of 3 (143 Views)
01-14-2014 08:15 AM in reply to: abulla
Dear abulla ,
Thank your for anwser.
I know which problem .I need to assiged the fitting in that properties:smileyhappy:
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
