Revit MEP Forum
Uncolor ducts
3 REPLIES 3
revitworkbench
308 Views, 3 Replies
Uncolor ducts
So I know how to color scheme ducts but how do you take it off? How do I remove the color scheme? you would think its obvious but its not...Thanks
3 REPLIES 3
CoreyDaun
in reply to: revitworkbench
If it is indeed a Color Scheme that is applying the color overrides, then under the View's Properties you can click the button beside "Color Scheme" and select "(none)" from the list of schemes on the left side of the following dialog.
revitworkbench
in reply to: CoreyDaun
Ah, Thanks, I had to select none in both Color Scheme and System Color Scheme. But thanks!
CoreyDaun
I was just coming back to add that - glad you caught it!
