Revit MEP
Active Contributor
Message 1 of 3 (226 Views)
Accepted Solution
URL Parameter based on family type
226 Views, 2 Replies
01-23-2013 12:02 PM
Not sure if this is something wonky on my system, or if it's a shortcoming of this parameter type.
To set the scene, we have one piece of equipment, that has 6 different configurations available.  Each configuration has it's own model number, and catalog page on our company website.
I created a family for this equipment, and added the URL to the catalog as an instance parameter.  For each family type, this is a different value, since it goes to a different portion of the website.  I also have several other parameters of various types, that change value based on family type.
They all work just fine in the family editor.  I can switch between the different family types at will, and see the URL for the catalog change correctly, along with the model number, schedule values, comments, etc.
When the family is inserted into a project though, everything BUT the URL parameter works.  The URL still shows, but it only ever shows the first link I entered in for the first type I created.  All other parameters switch correctly.
I searched around, but couldnt' find anything about this being a limitation of the URL parameter type.  Is it one, or is my Revit just busted?
*Expert Elite*
CADastrophe
Message 2 of 3 (218 Views)
Re: URL Parameter based on family type
01-23-2013 12:26 PM in reply to: bashworth
I quickly tested this Revit MEP 2013 (Update 2) with a couple random URL's with a catalog, and it worked as expected. Are you using this version with the current updates? Can you post your family and catalog file for us to investigate?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Active Contributor
Message 3 of 3 (187 Views)
01-24-2013 09:04 AM in reply to: CADastrophe
Thank you for your time on this.  Looks like it just needed some time in the corner to sit and think about what it had done.  Working correctly today.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
