Bill,
After discussing with our tutorials folks, I have a couple of questions.
* Are you sure that you set the slope correctly? If you set your slope backwards you might get similar results.
* Did you select "Sanitary" System Type when you adjusted the Offset settings in the Mechanical Settings dialog?
Let us know if those items result in the proper behavior.
Cheers,
Kyle B
Revit MEP Product Manager
Kyle Bernhardt
Director
Building Design Strategy
