Revit MEP
Message 1 of 6 (162 Views)
Accepted Solution
Trouble with Printing
162 Views, 5 Replies
09-25-2013 12:18 PM
Ok so now for some reason when I print, it is only printing my annotations and dimensions and leaving out all my model categories. Yet I can plainly see them on my sheet. Has anyone run into this before, or maybe know what the cause might be? Bause Im stumped! thanks!
Message 2 of 6 (147 Views)
Re: Trouble with Printing
09-25-2013 03:21 PM in reply to: michaelmead
I am attaching what it looks like
*Expert Elite*
CADastrophe
Message 3 of 6 (108 Views)
09-26-2013 06:29 AM in reply to: michaelmead
Are you printing with Raster Processing (under Print Setup)? If so, I would suggest switching it to Vector Processing.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 4 of 6 (99 Views)
09-26-2013 08:10 AM in reply to: CADastrophe
Well, I tried changing to vector processing. In print preview, it showed up as it was going to print. Then I selected the 4 sheets I wanted to print. Then it failed. It printed only the annotations again. ??
Michael Mead
BIM Director
Smith & Keene, Inc.
Commercial Division
833 Live Oak Dr.
Chesapeake, VA 23325
Office: 757-420-1231 ex.155
Product Support
alan.quinn
Message 5 of 6 (87 Views)
09-26-2013 11:19 AM in reply to: michaelmead
Try the following:
1. If this is a Worksharing file close it > re-open with Audit checked > Purge > then save-as > project > Options (lower right of save window) > check off Save this file as a new central after save > re-name and save > close > re-open and test printing. Also, check your Warnings.
2. Do you get the same results if you try printing from another PC?
3. Do all users get the same results?
4. Can you print to PDF?
5. Do you have large coordinates? Open the default 3D view > on keyboard hit ZA (zoom all) > can you see the geometry or this it get really small? If if go small you have an element out in space > find it and delete it.
6. Did the geometry get bigger than the 20 limit?
7. Did a CAD import land outside the 20 mile limit?
Let me know your results.
Alan Quinn
Support Specialist
Product Support
Autodesk, Inc.
Message 6 of 6 (77 Views)
09-27-2013 10:47 AM in reply to: alan.quinn
It was an isolated issue. I repaired the program using Autodesk repair. That fixed the problem.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
