We are a small company so the Designed By, Drawn By, Checked By parameters for the title block are the same for every sheet. Is there a way to make these type parameters instead of instance parameters?
Thanks in advance
Carrie
Solved by CarrieHoffman02. Go to Solution.
No, but I would suggest making it Text in lieu of a Label. Then you don't have to worry about the parameters at all.
Why not just create a schedule for batch alteration of title sheets and do all three parameters on all the sheets in one go?
I have 2 types of title blocks, Electrical and Mechanical. Text seemed easiest, but I ended up figuring out what I wanted in the first place. I just have a generic label that reads the drawn by and checked by type family paramters. After I woke up and realized what I was doing it was pretty simple.
Thanks for your input
