Revit MEP Forum
Tandem Circuit breakers in revit mep
7 REPLIES 7
Message 1 of 8
1706 Views, 7 Replies
does anyone knows how to make a tandem circuit breaker in a panel schedule in revit mep 2012?
7 REPLIES 7
Message 2 of 8
CoreyDaun
Welcome to the Discussion Groups!
There is no direct way to do this currently, but there is likely a relatively simple work-around. How do you indicate such a breaker on your typical drawings? Do you indicate this on both plan and on the panel schedule?
Message 3 of 8
Try checknig out various cutler hammer circuit breakers that are miniature or westinghouse. If you truly need tandem or triplex, quad breakers then visit eaton to get more information regarding poles, amps & family depending on which part you need. Try to find the right datasheet too.
Message 4 of 8
Anyone knows how to create the tandem circuit breaker in a panel schedule in revit mep 2014.
Message 5 of 8
Gabriel, did you ever find the way to create a  tandem circuit breaker in a panel schedule in revit mep????
Thank you.
Message 6 of 8
in reply to: CoreyDaun
did you have a workaround for showing tandem breakers? I'd love to hear it!
Message 7 of 8
brittany.hautakangas
Anyone know how to display a tandem breaker in the panel schedule?
Message 8 of 8
AFAIK, Revit does not have this option.
Fábio Sato
