Revit MEP Forum
Tag Leader
1 REPLY 1
bvm76
659 Views, 1 Reply
Tag Leader
is it possible to have a straight tag leader with the text perpendicular to the element you are tagging? please see attached.
Please mark Accept as Solution if your question is answered!
Thank You.
1 REPLY 1
gurselgunacar
in reply to: bvm76
You can use Attached End and change it to vertical. Be sure that in tag family rotate with compoment turned off.
https://www.bilgitara.com
