Hi All,
I'm trying to streamline my process by using keyboard shortcuts. Is there a way that I can add a tag with leader and without leader via a keyboard shortcut. I looked through the list for a while and couldn't find anything. Here is why I want this.
When I tag a piece of equipment, I want the leader attached to it. When I tag a revision cloud, I do not want the leader. I find it time consuming to do the following:
TG (tag)
(click off or on the leader checkbox)
click on what I want to tag.
What I would like is:
TL (Tag with Leader option turned on)
or
TG (Tag with Leader option turned off).
Anyone know if this is possible?
Thanks!
This is not currently possible, but I have seen a few users requesting the ability to use HotKeys to toggle the tools from the Options Bar. For example, I would frequently use:
□ Leader (when placing tags)
□ Multiple Alignment (when using the Align command)
□ Copy (when using the Mirror and )
□ Multiple (when using the Copy command)
The link below is often provided by Autodesk Support personnel here, and I highly recommend it use.
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
It's not exactly what's been described, but I have created an add-in that will toggle leaders for keynotes, text notes, and tags (including revision cloud tags) after placing and then selecting them. Since you can assign shortcut keys to add-ins, it's certainly faster than moving the cursor up to that checkbox every time. I'm happy to share the code and/or the .dll (Revit 2017). If you're interested, please send me a message.
Are you still offering the add-in for the tag leader on/off toggle?
That's a wonderful think you did there!
It's been a issue for a long time.
Would you mind sending me this add-in?
Thank you in advance! 🙂
After losing access to a previous email address, I've opened a new account on the forum. To request the add-in, please message me at this account. Thanks.
Could you forward the link to the add-in? This sounds simply wonderful! A big time-saver!
