If I try to create a New Proyect in revit mep 2014 without a template, and collapse Piping System in the Project Browser, "Other" system classification not appear.
Does exist any way to make it appear?
A capture is arrached.
Solved by CoreyDaun. Go to Solution.
Hello, and welcome to the Discussion Groups!
There is no means of simply creating it if it is not there. You can restore it to your "templateless" file by opening a new Project with the Mechanical Template and using Transfer Project Standards (located on the Manage tab) to bring the "Pipe System Types" into your Project. This will bring them ALL over, including the "Other" Pipe System.
