Revit MEP Forum
Symbol/Text in Electrical Family
3 REPLIES 3
2665 Views, 3 Replies
Hi
I am creating an electrical socket outlet and have created the extrusion using the electrical fixture family. I have then created a generic annotation for my symbol and added this to the ref. level in my family. I have then added a parameter to the symbol to allow me to control the positioning of my symbol when in 2D.
I now need to add text to the family i.e. a number 2 to represent double socket. What is the best way to do this, text, labels or tags.
 I would like my number 2 to remain 'readable' regardless of how the family is rotated/oriented. Is the workaround of inserting 4 instances of an annotation family with associated parameters the only viable solution to this and how would this be acvhieved if my socket was placed on a wall at an angle of say 28degrees for example.
3 REPLIES 3
Alfredo_Medina
The number "2" should be an annotation symbol. If it is text, it disappears. About the rotation, the most that Revit can do is keep numbers and letters "readable" which does not mean horizontal. It is possible to force a number or text to be horizontal, but only through manual input of a rotation angle to which the letter or number is tied to (since it requires manual input, it might lead to errors; maybe not worthy. "Readable" is fine, in my opinion).
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
CoreyDaun
Having gone through the trouble of creating rotating annotations to wall-mounted devices myself, I would recommend including this information in a Tag. This annotation could quite easily combined with your standard Electrical Device Tag. Having the annotation embedded in your Family destroys its flexibility regarding the location of the annotation - since it's embedded, it cannot be moved in the Project if need be.
in reply to: CoreyDaun
Thanks for the info both of you. I will use both methods depending on the family I am creating.
I have decided that for the double sockets I have tagged all by category with a tag that has a type parameter 'e.g. doubleSocket' associated with it, as stated in your reply this will allow me to easily move the text, especially when the socket is rotated about a random angle.
Corey, I looked at an example you posted regarding your 'rotated text' and it looked complicated, I will hopefully move onto more advanced annotation solutions in the future.
