Revit MEP Forum
Status Bar & properties disappearing
5 REPLIES 5
thombrady
507 Views, 5 Replies
Team
 I am working on a new project & I am having a new issue. While I am working all of a sudden my drawing is basically locked & when I click on a command it starts turning black & disappearing as well as my properties & project browser. It is easily fixed by closing the view & opening a new one but it seems to be happening with more frequency. I tried doing a screenshot but when I do it goes back to normal. Has anyone else run into this?
5 REPLIES 5
CoreyDaun
in reply to: thombrady
What version of Revit are you running?
Are any other users experiencing this?
Are you only experiencing this on that specific project?
thombrady
in reply to: CoreyDaun
Cad,
 #1 2014, we just upgraded for this project.
 #2 No, I am the only one.
 #3 Yes, so far.
  •  I have purged, compacted & deleted everything I could to make these files as small as possible for speed, (I have had issues before) & although I would like it faster this project has been OK. The Arch file is 133,008 KBs, MEP file is 75,868 KBs & the structural 29,480.
CoreyDaun
Have you tried toggling 'Hardware Acceleration' under Options?
thombrady
I had it off for speed but I just put it on, I will keep you up to speed! No pun intended.
thombrady
Cadastrophe,
 REVIT is a fickle system! I put the "hardware acceleration" on & now the machine is running better (Hopefully for good) & I have more speed! Must be an upgrade for 2014, In 2012 I had to shut off "hardware acceleration" to get the machine to run faster.
 Thanks again as always
