Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Sprinkler Symbol for Rotated Sprinklers
3 REPLIES 3
m.j.ferra
2607 Views, 3 Replies
Good Morning,
I am designing a fire sprinkler system using Revit MEP 2012, and have run into an issue with sprinkler symbols.  Part of our project building has a sloped ceiling, and by code, the sprinkler deflector must be parallel to the slope of the pipe run.  When I rotate our sprinklers to match the pipe run, the sprinkler symbol no longer shows up in plan view.  Is there some way we can show the sprinkler symbol in this situation?
I've attached pictures for clarification.
Thank you.
3 REPLIES 3
CoreyDaun
in reply to: m.j.ferra
This is a known issue, most infamously associated with lighting fixtures. I have a work-around I use to get light fixture on a sloped ceiling, show them properly oriented in the model, AND show our detail symbol over them. I created a separate family and rotate the model within the family to adapt to the slope. The light fixtures must then be mounted horizontally in the project in order for the Detail Item to display. Let me know if I can provide any more information or assistance!
Welcome to the Autodesk forums, m.j.ferra!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
m.j.ferra
in reply to: CoreyDaun
Ah, understood.  I created a rough family, and it appears to work.  Thank ou very much!
JoeRainey
Yeah, this is a strange issue, and has been an issue since the beginning. It's unfortunate that it continues to be an issue.
I also created a sprinkler family from scratch, I put an "angle" parameter into it, so that I can input the angle and the 3D model geometry will rotate within the familiy, while not rotating the family itself.
