Revit MEP
alatier
Message 1 of 3 (199 Views)
Splitting a pipe Revit 2012
199 Views, 2 Replies
01-07-2014 12:41 PM
I cant seem to break a pipe in revit 2012.
The split with gap doesnt work. The split adds a socket or a flange (depending on routing preferences), but mends itself when the fitting is deleted.
To wrap a beam or a duct, I am cutting a tee into the pipe to run around the obstruction, then deleting between the tees and converting the tees to elbows!
There must be a better way!
TIA
Pete
abulla
Message 2 of 3 (192 Views)
Re: Splitting a pipe Revit 2012
01-07-2014 01:18 PM in reply to: alatier
I don't think Split with Gap has ever worked correctly for MEP items unfortunately. If you split the pipe and then drag the ends away from the union it places, it shouldn't reconnect. Annoying I know.
alatier
Message 3 of 3 (185 Views)
01-07-2014 01:49 PM in reply to: abulla
Thanks Abdulla
You are saying thatr the best solution to adding a wrap is to split the pipe either side of the obstruction, then delete the pipe and the added sockets/couplings/flanges then re-route the pipe?
If this is the case, I hope they improve it in new versions
Cheers
Pete
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
