Revit MEP
Distinguished Contributor
kevinaldo
Message 1 of 6 (584 Views)
Space naming utility problem
584 Views, 5 Replies
09-15-2010 03:41 PM
Using 2011 Space naming utility, but it didn't transfer the information from the arch.rvt after creating spaces. Checked arch.rvt had created room and room tag.
anyone experienced it?
thanks,
Kevin
abulla
Message 2 of 6 (577 Views)
Re: Space naming utility problem
09-16-2010 06:31 AM in reply to: kevinaldo
Is your architectural link set to "Room Bounding"?
kevinaldo
Message 3 of 6 (572 Views)
09-16-2010 08:20 AM in reply to: abulla
yes it is; am able to create space but arch room names/numbers would not transfer by using space naming utility
abulla
Message 4 of 6 (569 Views)
09-16-2010 10:10 AM in reply to: kevinaldo
I've run into this problem before too, everything seems to be set up correctly, but the Space Naming just won't work. Still haven't figured out a solution.
New Member
terilw
Message 5 of 6 (514 Views)
09-23-2010 10:31 AM in reply to: abulla
We're currently having a similar problem with the Space Naming Utility. Spaces are being placed, no problem. However, when we run the utility "some" of the Spaces are getting the names and numbers pulled correctly.
I have a suspicion that our particular problem is caused the the Architect's varied use of Key Schedules for their rooms. They have two "Room Styles" available to choose from, although only one of them is actually used. The other is populated with 4 of the rooms, but not the rest. I can't see how to get rid of the un-used Room Style, so can't fully test that theory.
kevinaldo
Message 6 of 6 (506 Views)
09-23-2010 01:05 PM in reply to: abulla
Problem solved.
Went to Phases of our arch.rvt, it was "Complete" of New Construction and changed to "New", room names and numbers transferred.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
