Revit MEP
Employee
Message 1 of 3 (249 Views)
Solution - "Failed to open file" Error When Placing Pipe Transition
249 Views, 2 Replies
07-14-2006 07:31 AM
RSY Users,
I wanted to let all of you know of a fix to an issue that impacts the Pipe PVC Concentric Transition fitting that's available in the default model template in RSY.
A CSV file was not included with the installation files, and as a result you will get an error message if you try to place the fitting in your RSY model.
We will be including the necessary file in a future build of the program, but in the interim we wanted to make the file available to the user community. You will need to place the file at "C:\Documents and Settings\All Users\Application Data\Autodesk\Revit Systems\LookupTables\".
Please let me know if you have any issues with this solution to the problem.
Cheers,
Kyle B
RSY Product Support
Kyle Bernhardt
Product Line Manager
Building Design Suite
*jkemble
Message 2 of 3 (249 Views)
Re: Solution - "Failed to open file" Error When Placing Pipe Transition
07-14-2006 08:13 AM in reply to: KyleB_Autodesk
Where can we get this file?
wrote in message news:5237377@discussion.autodesk.com...
RSY Users,
template in RSY.
community. Yo
Employee
martin.schmid
Message 3 of 3 (249 Views)
07-14-2006 09:51 AM in reply to: KyleB_Autodesk
Looks like it was attached to Kyle's message :smileyhappy: If you didn't see the attachment, perhaps try the web-browser version of the news groups.
Cheers-
MS
Martin Schmid, P.E.
Product Manager - Revit MEP
Architecture, Engineering, and Construction
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
