I have an Intermittent gear drive assembly, transfered from AutoCAD 3D to Showcase. Teeth missing on driver give intermittent motion of driven @ a 3:1 tooth ratio, giving 1/4 turn forward of driven followed by dwell from a constant forward speed driver. When setting required RPM in Behavoirs, the resultant timebar is always pushed out to time necessary for one complete driven revolution?
Ant idea's how to shorten timebar, so dwell can be set correctly?
the showcase forum is here: http://forums.autodesk.com/t5/Autodesk-Showcase/ct-p/area-c18
DarrenP
