Revit MEP Forum
Showcase gear simulation
3 REPLIES 3
269 Views, 3 Replies
I have an Intermittent gear drive assembly, transfered from AutoCAD 3D to Showcase.  Teeth missing on driver give intermittent motion of driven @ a 3:1 tooth ratio, giving 1/4 turn forward of driven followed by dwell from a constant  forward speed driver.  When setting required RPM in Behavoirs, the resultant timebar is always pushed out to time necessary for one complete driven revolution?
Ant idea's how to shorten timebar, so dwell can be set correctly?
3 REPLIES 3
DarrenP
the showcase forum is here: http://forums.autodesk.com/t5/Autodesk-Showcase/ct-p/area-c18
DarrenP
in reply to: DarrenP
Simply reason! That was the one offered after search for Showcase problems.
UKAdmin
Forum now located.  Thanks for reply.
