Revit MEP
Active Contributor
ceaves
Message 1 of 2 (86 Views)
Shifting extrusions created with EQ
86 Views, 1 Replies
09-25-2013 09:15 AM
I’ve created this family that is mounted on two channel skid extrusions. I used the EQ command on them. I’ve tried making them separately, copied and mirrored, but I end up with the same problem.
When I load the family they shift on SOME of the types, mostly the larger ones. I can’t figure out why.
Thanks in advance for your help!
CADastrophe
Message 2 of 2 (58 Views)
Re: Shifting extrusions created with EQ
09-26-2013 06:01 AM in reply to: ceaves
Edit the extrusion for the skids, delete and recreate the dimensional constraints for the skid widths (4"), and then select them and click the lock icon to constrain them to that width.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
