Revit MEP
Valued Contributor
Message 1 of 4 (243 Views)
Setting Mark for VAV Boxes/Terminal Units to A Number + Room Number
243 Views, 3 Replies
08-27-2013 12:21 PM
Is there a way to set the Mark on a terminal unit to be a number, dash, then the room number?  Or even more specifically, A number from parameter concatenated with the room number the terminal unit is in?  If not, another option would be a column in a schedule which concatenates this information, the number in one column, and the room number in another column.
- Tim Smith
Motz Engineering
Revit MEP/AutoCAD/Sketchup
UC Architectural Engineering c/o 2016
"There is nothing more expensive than hiring cheap engineers." - Bob Sheeran, Xavier University 01/05/2005
CADastrophe
Message 2 of 4 (203 Views)
Re: Setting Mark for VAV Boxes/Terminal Units to A Number + Room Number
08-28-2013 09:13 AM in reply to: tim102289
No. The Mark Value is a unique system Parameter that is not accessible for manipulation by the user. I would recommend NOT relying on the Mark parameter for identifying equipment. For more information on this, search this forum for previous discussions. Here is the latest similar thread that I know of: How to lock a prefix on a mark per family
Regarding their use in schedules, your only option would be to display these values is separate columns in a Schedule - it is not possible to concatenate parameter values at this time.
Valued Contributor
Message 3 of 4 (173 Views)
08-29-2013 01:03 PM in reply to: tim102289
Would there be a way to make a column in the schedule that has 4-room_number (4-01 for example)?  I think I could make labels for the floor plans easy enough but it would be nice if this was something I could put in a schedule too, without manually typing them all in.
- Tim Smith
Motz Engineering
CADastrophe
Message 4 of 4 (168 Views)
08-29-2013 01:26 PM in reply to: tim102289
Unfortunately, there's just no way to combine the data from fields into one, or even to add a static prefix or suffix.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
